The project remains ready all the time, when I use vivado/2019.2 to synthesize my project.
When I use vivado/2019.2 to synthesize my project,the project remains ready all the time.
Im using CentOS 7.5.1804. When I use vivado/2019.2 to synthesize my project, it will promp: ERROR: Could not find 64-bit executable. ERROR: /opt/Xilinx/Vitis/Model_Composer/2019.2/bin/tps/lnx64/vrs does not exist. WARNING: /opt/Xilinx/Vitis/Model_Composer/2019.2/bin/tps/lnx64/jre9.0.4 does not exist. . And the project remains ready all the time. So I'm very confused about this.
Hi @lkme,
Seems like Vivado is not properly installed on your machine. Try reinstallation and check if it resolves the issue.
~Chinmay
