Vitis_HLS 2020.2 not starting only splash screen visible
Vitis hls (ver 2020.2) is not opening in the gui mode on windows. I only see a splash screen for a very brief time when I try to run the application.
I search for the issue on the forum and come across: https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/Vivado-HLS-2017-3-not-starting-only-splash-screen-visible/td-p/799934
following which I go to my C:\Users\username\.Xilinx\vitis_hls and delete all the files under this. This fails to resolve the issue.
then i follow https://forums.xilinx.com/t5/Vitis-Acceleration-SDAccel-SDSoC/Vitis-doesn-t-start/m-p/1074165
which asks to delete the .Xilinx folder from the above-mentioned location. When doing so I could delete all files except one file that is xinstall..it says the file is open in another program. I don't see that though..so I restart and try to delete that file, still says the same!
edmeme
Well, that was a ride. I think I fixed it!
Its rather cryptic: you need to edit one character on the file xilinx/Vitis_HLS/2020.2/common/scripts/autopilot_init.tcl
Go to line 40, should look like this
----%r&-'%rl%&n$&lt'v-=
Replace the last = with >, should look like
----%r&-'%rl%&n$&lt'v->
That should do. It'd be great if someone can confirm, I did a number of changes on my way that may play a role on it working for me.
That character decides whether an external java interpreter or a shared library is used to run vitis. I noticed that vitis' java side wont notice tcl is running and will try to launch it again. When loading the java interpreter on the same process the flag that indicates tcl is up is already set.
dm78
hi,
could you solve the problem? I'm facing the same on 3 linux machines too.
Vitis IDE and Vivado are launching, but Vitis_HLS not (all 2020.2). Only the splash screen is showing up and then, it dies silently, no log, no hint. I can start Vitis_HLS in interactive mode and it runs in tcl-mode, but not in GUI mode.
INFO: [HLS 200-10] Bringing up Vitis HLS GUI ...
INFO: [HLS 200-10] Creating directory /home/build/.mozilla/eclipse
INFO: [Common 17-206] Exiting vitis_hls at Tue Feb  9 20:58:54 2021...
2020.1 works fine on the same machines.
Can someone help?
watari
Hi @dm78
What is your OS ?
I haven't faced such issue with Vitis_HLS yet on CentOS 7.9.2009 (native x86_64 host).
dm78
Hi @watari,
my main development machine is an unsupported Arch Linux (but works with all versions and variants except HLS 2020.2).
But one of the three is a CentOS 7.5 environment.
Untill now, I'm always getting some kind of hint, why something is not working (eg. log files, missing libs messages, wrong permissions, etc), but now: nothing (at least, I'm not able to find it).
watari
Hi @dm78
Do you prepare enough memory and swap size ?
I suggest you to make sure them.
dm78
this should be no problem, there are 32GB of RAM and Gigs of swap available. This should enough.
And, HLS 2020.1 is working so far.
leuko
I also have the same problem on Ubuntu 20.04. Could someone start vitis_hls on Ubuntu 20.04?
dm78
hi,
I was able to start Vitis HLS on centos7 after updating systemd. No clue what the connection is.
leuko
I want to amend my post. I was using Ubuntu in systemd-nspawn (like LXC). After installing it in Virtualbox, it works.
@dm78I also mainly work on Archlinux, do you use Centos in a container?
dm78
Yes, I do. Currently, I'm using Centos6 (for ISE), Centos7 (Vitis/Vivado <= 2020.1) and Centos8 (>= 2020.2) successfully.
leuko
Do you use Docker for your containers?
dm78
sorry for the long delay,
i'm using podman. But currently, the vitis hls gui is not working anymore althought the container didn't changed.
leuko
In my case vitis_hls also still does not work.
I tried to debug the problem: vitis_hls tries to launch eclipse, and the following logfile is generated:
~/.Xilinx/vitis_hls/2020.2/workspace18/.metadata/.log
!SESSION 2021-03-23 08:09:09.006 -----------------------------------------------
eclipse.buildId=unknown
java.version=11.0.2
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments:  -showlocation -perspective com.autoesl.autopilot.ui.platform.perspective -application com.autoesl.autopilot.ui.platform.application
Command-line arguments:  -showlocation -clean -data /home/u/.Xilinx/vitis_hls/2020.2/workspace18 -perspective com.autoesl.autopilot.ui.platform.perspective -application com.autoesl.autopilot.ui.platform.application
!ENTRY org.eclipse.emf.ecore 2 0 2021-03-23 08:09:11.308
!MESSAGE Both 'com.autoesl.autopilot.ui.models' and 'com.autoesl.autopilot.ui.models' register a package for 'com.autoesl.autopilot.solution'
On Ubuntu the logs continue with:
!ENTRY com.autoesl.autopilot.ui.platform 1 0 2021-03-23 07:04:55.463
!MESSAGE HLS_Info: Finish initializing the SWIG data
!ENTRY org.eclipse.ui.navigator 4 0 2021-03-23 07:05:01.201
!MESSAGE An extension already exists with id "org.eclipse.egit.ui.RepositoriesViewContent".
!ENTRY org.eclipse.ui 2 2 2021-03-23 07:05:02.745
!MESSAGE Invalid preference category path: com.autoesl.autopilot.ui.startup.preferences.AutoPilotRootPreferencePage   (bundle: com.autoesl.autopilot.ui.cdfg.diagram, page: com.autoesl.autopilot.ui.cdfg.diagram.general)
Somehow on Archlinux it does not continue with SWIG data initialization.
dsakjl
Hi @leuko , hello everyone,
did you find a solution to this problem?
Thank you, best regards.
leuko
Nope.
dm78
I was able to reactivate my container. I changed the network-parameter to share the host network stack, but this lead to a not working HLS. Switching back to NAT fixed it and HLS works. I do not know, what the reason is, why HLS does not work with the arch linux network stack.
nderumig
I encounter exactly the same problem, with no solution found. Strace-ing Eclipse gave no interesting clue on what is going on.
rybaiho
I have the same problem on the Windows machine, but I can start Vitis HLS GUI from the Vivado Tcl Console entering vitis_hls command.
dsakjl
Hi @rybaiho ,
I tried on Linux but it doesn't work.
Thank you for the suggestion.
nderumig
Running in interactive mode `vitis_hls -debug -test` outputs:
DBG: vitis_hls_bin handler: showguiout=0
DBG: vitis_hls_bin handler: arg='tclscripts' used=1 default=
DBG: vitis_hls_bin handler: tclscripts=do_run
DBG: vitis_hls_bin handler: arg='terse' used=0 default=0
DBG: vitis_hls_bin handler: terse=0
DBG: vitis_hls_bin handler: arg='test' used=1 default=0
DBG: vitis_hls_bin handler: test=1
DBG: vitis_hls_bin handler: arg='testClassName' used=0 default=
DBG: vitis_hls_bin handler: testClassName=
DBG: vitis_hls_bin handler: arg='version' used=0 default=0
DBG: vitis_hls_bin handler: version=0
DBG: vitis_hls_bin handler: arg='workpath' used=0 default=
DBG: vitis_hls_bin handler: workpath=
DBG: vitis_hls_bin handler: arg='workspace-prefix' used=0 default=
DBG: vitis_hls_bin handler: workspace-prefix=
child process exited abnormally
    while executing
"close $hls_io"
    (procedure "::AP::do_run_autoclipse" line 146)
    invoked from within
"::AP::do_run_autoclipse $nosplash $test $testClassName $workpath $showguiout"
    (procedure "ap_internal_vitis_hls_bin" line 201)
    invoked from within
"ap_internal_vitis_hls_bin "
ERROR: [HLS 200-70] There is an error calling 'vitis_hls'; try '-help'.
vitis_hls> INFO: [Common 17-206] Exiting vitis_hls at Mon Apr 12 20:27:37 2021...
/opt/Xilinx/Vitis_HLS/2020.2/bin/vitis_hls -i  15,34s user 0,72s system 0% cpu 1:01:14,44 total
This may help to understand what is going on, though non of my `grep` led to any interesting result...
Thank you all for the suggestions.
edmeme
Same problem as everyone here. Running java with -verbose:class -Xcheck:jni I got this.
[2.358s][info][class,load] org.eclipse.core.internal.localstore.IUnifiedTreeVisitor source: file:/home/arch/wl/arch/opt/xilinx/Vitis_HLS/2020.2/lnx64/tools/eclipse/plugins/org.eclipse.core.resources_3.13.700.v20200209-1624.jar
[2.358s][info][class,load] org.eclipse.core.internal.localstore.ILocalStoreConstants source: file:/home/arch/wl/arch/opt/xilinx/Vitis_HLS/2020.2/lnx64/tools/eclipse/plugins/org.eclipse.core.resources_3.13.700.v20200209-1624.jar
[2.358s][info][class,load] org.eclipse.core.internal.localstore.RefreshLocalVisitor source: file:/home/arch/wl/arch/opt/xilinx/Vitis_HLS/2020.2/lnx64/tools/eclipse/plugins/org.eclipse.core.resources_3.13.700.v20200209-1624.jar
ReleasePrimitiveArrayCritical: release array failed bounds check, incorrect pointer returned ? array: 0x000064ab040798b0 carray: 0x000064aafcbf69c0
GuardedMemory(0x000064ab04079720) base_addr=0x000064aafcbf69a0 tag=0x000064aafcbf7cc0 user_size=1 user_data=0x000064aafcbf69c0
[2.358s][info][class,load] org.eclipse.core.internal.localstore.RefreshLocalAliasVisitor source: file:/home/arch/wl/arch/opt/xilinx/Vitis_HLS/2020.2/lnx64/tools/eclipse/plugins/org.eclipse.core.resources_3.13.700.v20200209-1624.jar
  Header guard @0x000064aafcbf69a0 is OK
  Trailer guard @0x000064aafcbf69c1 is BROKEN
  User data appears to be in use
FATAL ERROR in native method: ReleasePrimitiveArrayCritical: failed bounds check
	at org.eclipse.swt.internal.gtk.OS.g_object_get(Native Method)
	at org.eclipse.swt.widgets.Display.checkAndSetThemeDetails(Display.java:1115)
	at org.eclipse.swt.widgets.Display.createDisplay(Display.java:1135)
	at org.eclipse.swt.widgets.Display.create(Display.java:1071)
	at org.eclipse.swt.graphics.Device.<init>(Device.java:176)
	- locked <0x0000000726414a20> (a java.lang.Class for org.eclipse.swt.graphics.Device)
	at org.eclipse.swt.widgets.Display.<init>(Display.java:637)
	at org.eclipse.swt.widgets.Display.<init>(Display.java:628)
	at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:777)
	at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:167)
	at com.autoesl.autopilot.ui.platform.Application.start(Application.java:88)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(java.base@11.0.2/Native Method)
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(java.base@11.0.2/NativeMethodAccessorImpl.java:62)
	at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(java.base@11.0.2/DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(java.base@11.0.2/Method.java:566)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
[1]    27748 abort (core dumped)   -verbose:class -Xcheck:jni -Xms512m -Xmx4096m -XX:+HeapDumpOnOutOfMemoryErro
Is this a GObject error?
edmeme
Not sure if this is relevant, but I also found a mistake in lnx64/tools/eclipse/plugins/com.autoesl.autopilot.ui.models_1.0.0.jar:plugin.xml
This entry is duplicate:
   <extension point="org.eclipse.emf.ecore.generated_package">
      <!-- @generated APProjectModel -->
      <package
            uri="com.autoesl.autopilot.solution"
            class="SolutionFile.SolutionFilePackage"
            genModel="model/APProjectModel.genmodel"/>
   </extension>
nderumig
This looks like an Eclipse error, now solved (reported 2020-05-08) https://bugs.eclipse.org/bugs/show_bug.cgi?id=562951. Looking at the `org.eclipse.swt.gtk.linux.x86_64_3.114.0.v20200304-0601.jar` file, the embedded Eclipse version date back to 2020-03-04, before patching. That may explain the issue?
edmeme
Unfortunately, does not look like this is the culprit. Checking the code, its easy to avoid the GDK error by having a GTK_THEME env defined. It made the error in the log go away, but vitis wont start either way.
edmeme
jul
Thank you so much! I tested your fix on Arch Linux and finally Vitis is starting normally.
nderumig
That worked for me, many thanks!!!!
dsakjl
Hi @edmeme ,
thank you so much. This solved the problem!
Best regards.
rybaiho
This solution doesn't work on my Windows machine. I can lunch Vitis HLS GUI only from Vivado 2020.2 Tcl Shell (but not from Vitis HLS 2020.2 Command Prompt) by entering vitis_hls command.
edmeme
Vitis opens, I have lots of other issues on top. Can everyone else create a project?
