Visitor abregnsbo
[Vivado 12-1773] No legal targets specified. Supported targets for this IP are: all
I am getting this error with this command:
  generate_target {instantiation_template} [get_files $ip_dir/$ip_name/$ip_name.xci]
It happens if I having generated & synthesized an IP, open the project again, and try to regenerate the IP.
I have looked for how to delete IP from a project, i.e. the opposite of 'create_ip' but could not it. How do I delete IP from a project ?
My tcl code:
if {[file exists $ip_dir/ip_lib.xpr]} {
  open_project $ip_dir/ip_lib.xpr
} else {
  create_project -force ip_lib $ip_dir -part [Tech_Board2Part $board]
set_property ip_repo_paths $PROJECT(FPGA,ip_base_dir)/packaged_IP [current_project]
update_ip_catalog
create_ip -force -name $ip_base_name -vendor xilinx.com -library user -dir $ip_dir -version 1.0 -module_name $ip_name
generate_target {instantiation_template} [get_files $ip_dir/$ip_name/$ip_name.xci]    ;# FAILS 2nd time I run this code
generate_target all [get_files $ip_dir/$ip_name/$ip_name.xci]
catch { config_ip_cache -export [get_ips -all $ip_name] }
export_ip_user_files -of_objects [get_files $ip_dir/$ip_name/$ip_name.xci] -no_script -sync -force
create_ip_run [get_files -of_objects [get_fileset sources_1] $ip_dir/$ip_name/$ip_name.xci]
launch_runs -jobs 4 -verbose "${ip_name}_synth_1"
wait_on_run "${ip_name}_synth_1"
close_project
回复: [Vivado 12-1773] No legal targets specified. Supported targets for this IP are: all
How about adding -force to generate_target command so as to overwrite existing output products?
For deleting the IP, you may want to try remove_files.
