Visitor avic
Vivado 2015_1 FIFO simulation problem
i generated distributed fifo.
in sim folder i have this file
the place this module - fifo_generator_v12_0
i cant find this module for simulation. i have a folder with that name but without a sumulation file.
in the simulation folder (of fifo generator v_12) i have only "fifo_genrator_vlog_beh" file.
how i can run this fifo simulation
Re: Vivado 2015_1 FIFO simulation problem
Check the below article http://www.xilinx.com/support/answers/61035.html
You can use the below command to report all IP files necessary for simulation
get_files -compile_order sources -used_in simulation -of_objects [get_files <IP_Name>.xci]
Deepika.
Deepika.
You can also use below commands at tcl console which will generate the compile.bat,elaborate.bat and simulate.bat Generate_scripts in the .../sim-1/behav folder which can be used to simulate the core is standalone Modlesim.
set_property target_simulator ModelSim [current_project]
launch_simulation -scripts_only
Satish
