Newbie mikeharpe
Vivado 2015 file open very slow
When I try to do most any menu function that requires navigation and opening a file Vivado takes a long time to load the dialog.
An example is Add Source...
When I click on it the dialog box showing the files takes over a minute to appear. Sometimes navigating is very sluggish, sometimes it's not.
Any suggestions?
Tags (3)
Re: Vivado 2015 file open very slow
@mikeharpe
Looks like machine specific issue to me, can you try re-installing the tool? Also, make sure you are using supported OS:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug973-vivado-release-notes-install-license.pdf
Anusheel
Helpful answer -> Give Kudos
Anusheel
