afgarrido
Vivado 2017/2018 Max CPU Cores
I am looking to speed up my vivado projects and wanted to know the max cpu cores that vivado can utilize in the following tasks:
                [ Simulation / Systesis / Implemenation ]
for Vivado versions 2017 - 2018.
Also does vivado support two processors in the same PC?
surajc
@afgarrido
please have a look at this forum post
It is similar to your query
https://forums.xilinx.com/t5/Design-Entry/Change-the-default-number-of-threads-on-Vivado/td-p/309505
--Suraj
Kindly note- Please mark the Answer as "Accept as solution" if the information provided is helpful.
rshekhaw
Hi @afgarrido
The default number of cores used will be 4.
You can override this parameter by :
set_param general.maxThreads <new limit>
For implementation check page no.7:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug904-vivado-implementation.pdf
For synthesis check page no.37:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug901-vivado-synthesis.pdf
For simulation check pag no.206:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug900-vivado-logic-simulation.pdf
Raj
afgarrido
I see that 8 threads is the max setting for running implementation in parallel.  If I have a 24 core processor vs a 8 core processors will the implementation speed up by 3x?
afgarrido
Just bumping the thread to see if I could get an answer to the question stated in the previous post.
