Vivado 2017.4 crashes when moving from simulation to BD
opening project in 2017.4 (did not migrate or anything. Always worked with 2017.4). Running simulation, all is fine and working well. After simulation is finished I want to return to BD. I click on Open Block Design and Vivado crashes without any warning. In the folder sim there's a file named: hs_err_pid8332.log
Which has the error:
# An unexpected error has occurred (EXCEPTION_ACCESS_VIOLATION)
Stack:
no stack trace available, please use hs_err_<pid>.dmp instead.
This happens every time.
Upgrading to 2018.2 solved this issue.
@roymesi2
Try closing the simulation window and then open the block design from default vivado layout.
Anyways tool should never crash. If you can share the archive project, I can test it on my end in latest 2018.2 build.
--Syed
Ok, thanks. I want to go to BD, fix something and then re-run simulation... if I close the simulation, then re-run from scratch will take a long time...
@roymesi2
Can you try in 2018.2? Is this crash specific to one vivado project? Try checking on Xilinx example design (base zynq)
--Syed
Ok, will try and get back.
since I'm kinda new in Vivado, what is the correct way to run simulation AFTER changing something in the BD? I mean, I can "generate output products", etc.
Obviously I need to do some form of synth in order to take the changes into account.
@roymesi2
Check out my posts in below link which has links of user guides, tutorial which will help new beginners with Vivado.
https://forums.xilinx.com/t5/General-Technical-Discussion/Vivado-Book/m-p/905447/highlight/true#M42248
--Syed
Ok, thanks.
Since it is a simple question, can you help and give the straight answer instead of me going over hundreds of pages in order to find the answer?
:o)
@roymesi2
Yes, after making the BD changes, you will need to regenerate the output products
--Syed
