Visitor garankonic
Vivado 2017.4 - heap error bug
Dear all,
While developing with Vivado 2017.4 (CentOS), I have noticed some bug in the code parser (also in my code, of course).
If one defines something like this:
type type1 is (header1, header2, data);
signal signal1 : type1;
type type2 is (header1, header2, data);
signal signal2 : type2;
And then starts to use it as:
signal1 <= header1;
signal2 <= header1;
Which is wrong, I agree (!) - Vivado becomes completely mad: there are no error messages, but the file parsing fails (throws "heap error") and all the modules in the project (I have around 200) become invalid, also the top module is not able to be assigned anymore. Even more, if one has any other syntax errors in the file, the project will remain invalid even after removal of the initial cause - until all the syntax errors are solved.
Sure, one should not write such a crazy code, but treatment of this fail case may help other people.
Thank you a lot for your attention.
Newbie misterioso
Re: Vivado 2017.4 - heap error bug
I am facing a very similar error, too. The Vivado 2017.3 was crashed when I run RTL elaborated design. Then every time when I open a project, there is no detected modules(all are non-module files, around 300 files) and vivado shows two error information:
  • [filemgmt 20-2001] Source scanning failed (heap error) while processing fileset "sources_1" due to unrecoverable syntax error or design hierarchy issues. Recovering last known analysis of the source files.
  • [filemgmt 20-2001] Source scanning failed (heap error) while processing fileset "sim_1" due to unrecoverable syntax error or design hierarchy issues. Recovering last known analysis of the source files.
I tried re-install but it doesn't work.
My OS is Windows 7 SP1.
I will be appreciate if someone could provide some solutions
Hi @garankonic,
Can you please help us with some test-case of this issue?
Prathik
Don't forget to reply, kudo, and mark the appropriate post as 'accept as solution'.
Visitor gerardol
I'm facing the same issue in 2019.1:
Any suggestions?
Visitor gerardol
Hi all,
FYI, after experimentation I found that the issue was due to nested includes. i.e in bob.v I have the following:
`include "bob_includes.v"
If bob_includes.v contains:
`include "module_1.v"
I get a:
"[filemgmt 20-2001] Source scanning failed (heap error) while processing fileset "sources_1" due to unrecoverable syntax error or design hierarchy issues. Recovering last known analysis of the source files."
Hopefully that helps someone!
