Vivado Code Completion
I see that there are three options for code completion. On demand with Ctrl+Space, As you type and Disabled.
My issue is that it just does not seem to work. I see no code completion at all. Syntax checking seems to work, as I get the red wiggled lines. What am I missing?
I am using Vivado 2019.2.1 in an Ubuntu system. There is no error message (any more) in the stating terminal, so no obviouse missing library or so.
Are you all saying that your code completion in vivado is working???
I am testing code completion and it works.  Make sure you turn on the Sigasi mode in the project settings.  Its under text editor -> syntax checking
This is an EA feature in 2019.2.  It will be default in 2020.1
