Vivado Design Suite
I have downloaded and installed Vivado design suite in my PC. But I am unable to open the Vivado window from command terminal. It says that no such file or directory exists.
Re: Vivado Design Suite
Hi @pournimapr ,
You can open Vivado from the Tcl shell (i.e. Vivado 2018.3 Tcl Shell). This application can be opened from the "Xilinx Design Tools" in the Windows icon. (See attached image for reference)
Opening the Tcl shell will open a terminal window:
     Vivado%
Then, type in start_gui to open Vivado:
     Vivado% start_gui
Or add the bin directory to your path.
Are you windows or Linux ?
do you need the cmd prompt, or would the GUI work for you ?
If you want to run from a dos prompt, you need to use the xilinx dos box, as that has the environment set up
