Newbie rpkh
Vivado bug; auto create vhdl file
The creation of a new vhdl source via the project manager (Add sources) is not done correctly.
After defining the module, immediately a syntax error is generated for the file.
Opening the file reveals the error. "entity <source name> is" is defined twice.
Re: Vivado bug; auto create vhdl file
Welcome to Forums.
This is a known issue in vivado 2013.2. It has been reported to our development team for fix.
As a workaround for now, edit the file manually after creating the VHDL source file.
Cheers,
Deepika.
Deepika.
