bader@gctnet.de
Vivado doesn't run anymore URGENT HELP NEEDED
As already posted in another forum, my Vivado 2018.2 doesn't work anymore since today. Opening an exsisting project leads direct to a crash of Viado (after start it simply closes by itself ).
Creating a new project works until i try to "Create HDL Wrapper". The top level module is inserted as a
"non-module-file" and i got the following messages:
[filemgmt 20-2001] Source scanning failed (launch error) while processing fileset "sources_1" due to unrecoverable syntax error or design hierarchy issues. Recovering last known analysis of the source files.
[filemgmt 20-2001] Source scanning failed (launch error) while processing fileset "sim_1" due to unrecoverable syntax error or design hierarchy issues. Recovering last known analysis of the source files.
I have completely deinstalled Vivado, and install it from scratch, but it is the same.
Can someone please help me
tanders
Please check out this AR
https://www.xilinx.com/support/answers/71064.html
It should resolve this issue for you.
tanders
bader@gctnet.de
I have uninstalled vivado , removed everything from registry and from C:\Users\xxxx\AppData\Roaming\Xilinx.
Then made a new install, and it worked again.
But thanks for th link.
bader@gctnet.de
It is not right what i said, only Vivado works again !!
When i export the Hardware, Vivado misses to export some files (iE include files from my IP) , and the
SDK crashes when changing options in the BSP.
What a problem does this program havee ???
Is it not possible to delete and install it fromn scratch and then it works again ?
What can i do ?
How can i bring my project back to life. I cannot belive it .....
bader@gctnet.de
So i have one question :
Which folders from a vivado project can i safely delete without destroying my project ?
Name is project_1:
project_1.cache ?
project_1.hw  ?
project_1.runs ?
project_1.sim ?
tanders
Please upload the .metadata/.log file from your workspace so we can review it.
bader@gctnet.de
Today i can at least open Eclipse again.
In the attachment you will find 2 files
First is log1.rar where i have tried to change some options in the BSP. Result is a crash of Eclipse.
In the second log2.rar i have tried to delete a file out of the project. Result is the same, crash of Eclipse.
bader@gctnet.de
Now it's over again, Eclipse doesn't work anymore. Simply saying "Add new C file" leads to a total crash.
No editing possible anymore.
In the picture is the message, and hin the txt file are the details.
What is the problem with this program ?
tanders
Please create a new workspace and import your project from the workspace that's giving you issues.  This should allow you to move forward.
We will review what you have given us and report back.
bader@gctnet.de
This doesn't help ! And when i create a new workspace, Vivado doesn't find it anymore !
Yesterday i installed a new Version of JAVA ( 10.0.0.2 ) and everything looks good.
Today i started SDK and the compile errors coming up f_open,f_close and so on not found.
I have to remove xilffs from BSP, compile everything, and add it agian, again compile everything and it works.
Then i want to delete an unneeded file, and that was it -> SDK crashes ( disappears ) and after a new start
the same error ( i think the project is destroyed ).
tanders
Sorry to hear you are still having issues.
SDK should only be using the Java that it came with.  The Java version on your machine shouldn't affect Xilinx tools.
Thanks for confirming we're doing w/ a crash and not just an exception. There should be an hs_err_pidXXXX.log created by the crash in the working directory of SDK.
Please upload this file.
bader@gctnet.de
Sorry, but i cannot send you such files, for the moment, because they will not be created. I can work for the moment, but
i.E. when  i want to change the DHCP options, SDK crashes  ( disappears ) without message. Below are the last entries in
the logfile. But for the moment i can restart SDK and continue working.....
!ENTRY com.xilinx.sdk.utils 0 0 2018-08-27 09:08:07.987
!MESSAGE XSCT Command: [::hsi::utils::set_comp_param -hw C:/Daten/xilinx/project_lidar1/project_lidar1.sdk/design_1_wrapper_hw_platform_0/system.hdf -sw C:/Daten/xilinx/project_lidar1/project_lidar1.sdk/prj_lidar_bsp/system.mss -parameter dhcp_does_arp_check -value "true"], Thread: main
!ENTRY com.xilinx.sdk.utils 0 0 2018-08-27 09:08:07.993
!MESSAGE XSCT command with result: [::hsi::utils::set_comp_param -hw C:/Daten/xilinx/project_lidar1/project_lidar1.sdk/design_1_wrapper_hw_platform_0/system.hdf -sw C:/Daten/xilinx/project_lidar1/project_lidar1.sdk/prj_lidar_bsp/system.mss -parameter dhcp_does_arp_check -value "true"], Result: [null, true]. Thread: main
!ENTRY com.xilinx.sdk.utils 0 0 2018-08-27 09:08:11.060
!MESSAGE XSCT Command: [::hsi::utils::set_comp_param -hw C:/Daten/xilinx/project_lidar1/project_lidar1.sdk/design_1_wrapper_hw_platform_0/system.hdf -sw C:/Daten/xilinx/project_lidar1/project_lidar1.sdk/prj_lidar_bsp/system.mss -parameter lwip_dhcp -value "true"], Thread: main
!ENTRY com.xilinx.sdk.utils 0 0 2018-08-27 09:08:11.066
!MESSAGE XSCT command with result: [::hsi::utils::set_comp_param -hw C:/Daten/xilinx/project_lidar1/project_lidar1.sdk/design_1_wrapper_hw_platform_0/system.hdf -sw C:/Daten/xilinx/project_lidar1/project_lidar1.sdk/prj_lidar_bsp/system.mss -parameter lwip_dhcp -value "true"], Result: [null, true]. Thread: main
urjitmodhia
I am having the same issue even I tried re-installing vivado but not works and the link is also not working.
viggy
https://www.xilinx.com/support/answers/71064.html isn't available anymore. Was there a resolution to this? I cannot run Vivado 2018.1 or 2018.3 anymore. No log output, no nothing. Just a message box that says "launcher timed out".
I can't even get the Tcl shell to run (the shortcut opens a command window, with a standard Windows command prompt!).
Viggy
