Vivado - general
I am running a project in Vivado (v2018.3 (64-bit)).
Can you tell me why I keep getting this error message and how to fix it?
  • [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command.
>>Eric
Re: Vivado - general
Hey -
I was running from the gui.
Eventually, this message quits repeating.  I cannot currently "re-energize" it.
It just seems strange that with an open design in the gui, the message calls for openning it again.
@eholtzclaw
The command which you are running is valid on open elaborate or synthesized or implemented design.
Few TCL commands need the design to be opened in elaboration/synthesis/implementation for running.
Example get_cells command
Can you share the snapshot of error message with TCL command used or share the log file which has this error message.
--Syed
Hi @eholtzclaw ,
You need to open design whether Elaborated, synthesis, implemented before prooeeding for further phase or analysis.
  • RTL Analysis -> Open Elaborated Design
  • Synthesis -> Open Synthesis Design
  • Implementation -> Open Implemented Design
Raj Singh
Are you using the GUI ?
Some tabs / instructoins can only be preformed once a design has been synthesised or P&R
For instance, if you want to report timming sumary, then synthesis has to be done. BUT this could also be the implimented design.
so if you double click the open synthesised desing, then the report timing summary wil be available for the post symthesised design.
I guess this structure all comes out as the Xilinx people seem to do mainly TCL based runs, not GUI based,
Hey -
