Visitor avi833
Vivado simulation signal name path removing
someone maby knoew how to disable signal path discreption from xilinx vivado simulation???
in the red cycle
Re: Vivado simulation signal name path removing
Click on the signal in the testbench window, Right click, then click on Name-->Short.
Nupur
Click on "Accept as solution" if it solved your query, give kudos if it led you to the solution.
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
