Visitor avi833
Vivado simulation signal name path removing
someone maby knoew how to disable signal path discreption from xilinx vivado simulation???
in the red cycle
Re: Vivado simulation signal name path removing
Click on the signal in the testbench window, Right click, then click on Name-->Short.
Nupur
Click on "Accept as solution" if it solved your query, give kudos if it led you to the solution.
Nupur
