Vivado warning bugs
I'm using vivado 2015.4 in Ubuntu 14.04.2 x64.
During synthesis I get the following warnings in messages (see attached screenshot along with offending code):
There is nothing in the logs.
Meanwhile from top level:
get_pins -hierarchical -filter {NAME =~ "*radio_clk_gen/*/CLKOUT0"}
radio_clk_gen/inst/mmcm_adv_inst/CLKOUT0
get_pins -hierarchical -filter {NAME =~ "*radio_clk_gen/*/CLKOUT1"}
radio_clk_gen/inst/mmcm_adv_inst/CLKOUT1
BR,
Nikos
Re: Vivado warning bugs
@nibal
Looks like the tool is not able to find the specified net in the netlist. Open the synthesized design and check for the net/pin name and edit the XDC with the new name.
Anusheel
Helpful answer -> Give Kudos
Hi @anusheel,
Posted queries were run on the synthesized schematic. I opened the schematic myself, navigated to the path reported by query result, and found requested pins.
No renaming needed in xdc file. Seems to be a tool bug :(
BR,
Nikos
