What is the difference between clock jitter or Clock Uncertainty
I read timing guide. Some calculation needs both the clock jitter or Clock Uncertainty. I don't find a definition of these two terms. Such as this:
The equation for the setup analysis is the data path delay plus the synchronous element
setup time minus the clock path skew.
Setup Time = Data Path Delay + Synchronous Element Setup Time - Clock Path Skew
Could you explain it to me?
Re: What is the difference between clock jitter or Clock Uncertainty
Clock skew = two different Flip-Flops receive the clock signal at slightly different times due to the difference in clock net length (usually the clock is routed as a H-tree to reduce it as much as possible).
Clock jitter = On the same Flip-Flop, the position of the clock edge moves from edge to edge due to the oscillator noise/stability.
Clock uncertainty = I'm not sure. The fact that an edge is neve perfect and that you can't say precisely when it was taken into account by the Flip-Flop?
Even more complicated, I see the following on the IDE project timing report.
There are clock jitter, clock skew and clock uncertainty. Some are redundant or they are all different?
Slack (setup path): -0.559 ns (requirement - (data path - clock path skew + uncertainty))
Historian
Historian
Clock uncertainty is a calculated value that includes a number of sources of uncertainty
   - the clock jitter (both random and discrete, both system and input clock)
   - the phase error of any clock management element (CLKIN -> CLKOUT phase error)
You can see the calculation by clicking on the "Clock Uncertainty" in a detailed path report
Avrum
