Where can I find IP core demo in Vivado 2017.4?
Hi,all
I can find the IP core demo in  **\sources_1\ip\mig_ddr3\mig_ddr3\example_design folder when I use Vivado 2017.3. But I can not find the IP core demo  when I use Vivado 2017.4.
I would like to ask you where to find the  IP core  demo in Vivado2017.4?
hgtcs
Re: Where can I find IP core demo in Vivado 2017.4?
Hi @hgtcs,
In your case Open IP example design option is grayed out because it may possible that, that IP does not contain any example design.
To check that, you need to click on IP documentation option which is just below the open IP example design and click on view product guide and check in that if the example design will be provided or not.
i.e. DSP48 Macro v3.0 IP does not contain any example design and it shows like this in its product guide.
hemangd
hemangd
@hgtcs,
Do you mean example_design of the IP core?
For this Vivado creates an entirely new project.
FPGA enthusiast!
All PMs will be ignored
Yes, I want to find the example_design of the IP core. I create a new project and instantiate the IP core. But I don't know how to use it. So I want to refer to the example_design. Thank you.
Thank you for your reply!
Just launch the xpr file and Vivado will open the project. Then do Run Simulation.
FPGA enthusiast!
Hi @hgtcs
When you create a new project and instantiate IP, go to xci file in the sources hierarchy. Right click, select and click Open IP example design. This will open IP example design in a new project for you.
Rohit
Rohit
And if your in VHDL,
   good luck
Xilinx only support verilog examples,
     so they won't tell you much ,
I can not click Open IP example design.
Hi @hgtcs,
hemangd
hemangd
Hi @hgtcs
As correctly mentioned by @hemangd, some IPs don't have example design and you can verify that by clicking IP documentation option below open IP example design.
But as you wish to open example design of MIG IP which does have its own example design, so not sure why are you not seeing this option. Could you please share the complete screenshot of sources hierarchy.
Also if you wish to open example design of any custom IP then that option will not be there.
Rohit
Rohit
