pherem1
XC6SLX75-2FGG484I list pins
Hello , i'm looking for list pins in aldec (.csv) format.
Best regards
kkn
check if the following attachment helps
vemulad
Hi @pherem1
You can download the ASCII files here http://www.xilinx.com/support/packagefiles/spartan-6-pkgs.htm
Deepika.
umamahe
The below link documents also having useful information for you
http://www.xilinx.com/support/answers/64807.html
http://www.xilinx.com/itp/xilinx10/help/iseguide/mergedProjects/pace/html/pace_p_importingexportingcsvfiles.htm
pratham
@pherem1 Another way would be just create a project with your fpga part and package, run project till place and route. Navigate to prohect diectory look for a file named<entity_name>_pad.csv in the project directory. You will get the .csv you are looking for
-Pratham
