Visitor tony88
attribute 'event in Vivado
is attribute 'event supported in Vivado? if isn't supported how can I replace?
Re: attribute 'event in Vivado
This use of  'event is definitely not supported
if(count_up'event) then
as it is not synthesizable due to a need for dual edge asynchronous resource.  I don't think that you really intended this to behave this way at all and the code should have been written something like this.
read_process: process( M_AXIS_ACLK)
begin
if (rising_edge(M_AXIS_ACLK)) then
  if(count_up = '1' ) then
    case (current_state_read) is
      when Idle =>
        M_AXIS_TLAST<='0';
        M_AXIS_TVALID<='0';
        count_en<='0';
        M_AXIS_TDATA <=(others=>'0');
        if(fifo_ok='1' AND fifo_empty='0') then
          next_state_read<=SEND;
          fifo_rd_en <='0';
        else
          fifo_rd_en <='0';
          next_state_read<=IDLE;
        end if;
      when Send =>
        if(M_AXIS_TREADY='1') then
          fifo_rd_en <='1';
          count_en<='1';
          M_AXIS_TDATA <=fifo_rd_data;
          M_AXIS_TVALID<='1';
          if(count_up = '1') then
            next_state_read<=Send_Last;
            M_AXIS_TLAST<='0';
          else
            next_state_read<=Send;
            M_AXIS_TLAST<='0';
          end if;
        else
          count_en<='0';
          M_AXIS_TLAST<='0';
          M_AXIS_TVALID<='0';
          fifo_rd_en <='0';
        end if;
      when Send_Last =>
        count_en<='0';
          fifo_rd_en <='1';
          M_AXIS_TVALID<='1';
          M_AXIS_TLAST<='1';
          next_state_read<=Idle;
        else
          fifo_rd_en <='0';
          M_AXIS_TVALID<='0';
          M_AXIS_TLAST<='0';
        end if;
      when others =>
        count_en<='0';
        fifo_rd_en <='0';
        M_AXIS_TVALID<='0';
        M_AXIS_TLAST<='0';
      end case;
    end if;
  end if;
end process;
The code above is likely not 100% correct as I noticed that in addition to the original count_up'event you also had an if statement inside with "count_up = '1'".  I don't know what your intention was on the use of this signal.
'event  attribute is supported in Vivado.
Are you facing any issues in using it?
Visitor tony88
Thanks for your reply.
I'm using Vivado 2013.4 and I'm creating a custom IpCore in VHDL language. When I use 'event attribute I received the following error:
[Synth 8-26] attribute 'event not implemented
Historian
Historian
In what context are you using this attribute? Show code.
Is it possible to share the code to figureout the root cause?
Visitor tony88
read_process: process( M_AXIS_ACLK, current_state_read, count_up)
begin
when Idle =>
M_AXIS_TLAST<='0';
M_AXIS_TVALID<='0';
count_en<='0';
fifo_rd_en <='0';
else
fifo_rd_en <='0';
end if;
when Send =>
fifo_rd_en <='1';
count_en<='1';
M_AXIS_TVALID<='1';
M_AXIS_TLAST<='0';
else
M_AXIS_TLAST<='0';
end if;
else
count_en<='0';
M_AXIS_TLAST<='0';
M_AXIS_TVALID<='0';
fifo_rd_en <='0';
end if;
when Send_Last =>
count_en<='0';
fifo_rd_en <='1';
M_AXIS_TVALID<='1';
M_AXIS_TLAST<='1';
else
fifo_rd_en <='0';
M_AXIS_TVALID<='0';
M_AXIS_TLAST<='0';
end if;
when others =>
count_en<='0';
fifo_rd_en <='0';
M_AXIS_TVALID<='0';
M_AXIS_TLAST<='0';
end case;
end if;
end process;
This process attempts to write on axi stream bus.
begin
      when Idle =>
        M_AXIS_TLAST<='0';
        M_AXIS_TVALID<='0';
        count_en<='0';
          fifo_rd_en <='0';
        else
          fifo_rd_en <='0';
        end if;
      when Send =>
          fifo_rd_en <='1';
          count_en<='1';
          M_AXIS_TVALID<='1';
            M_AXIS_TLAST<='0';
          else
            M_AXIS_TLAST<='0';
          end if;
        else
          count_en<='0';
          M_AXIS_TLAST<='0';
          M_AXIS_TVALID<='0';
          fifo_rd_en <='0';
        end if;
      when Send_Last =>
        count_en<='0';
          fifo_rd_en <='1';
          M_AXIS_TVALID<='1';
          M_AXIS_TLAST<='1';
        else
          fifo_rd_en <='0';
          M_AXIS_TVALID<='0';
          M_AXIS_TLAST<='0';
        end if;
      when others =>
        count_en<='0';
        fifo_rd_en <='0';
        M_AXIS_TVALID<='0';
        M_AXIS_TLAST<='0';
      end case;
    end if;
  end if;
end process;
Visitor tony88
yes, It is not properly correct, it was only an example. Thanks for your reply.
