changing vivado project location
I changed my vivado project location but some source file remained in the previous location. Now the previous folder is deleted but my project seems to be searching for those file in the deleted folder.
[IP_Flow 19-682] TTCL input file '/home/athar/adi/hdl-adrv9361z7035_ccfmc_util_axis_fifo_rx_example/library/common/ad_pps_receiver_constr.ttcl' is not readable.
I got this error when i ran synthesis. I don't know how to change the directory to current path. I got more than 100 such files so manually adding doesn't seems feasible.
Re: changing vivado project location
Try disabling IP Cache:
Tools --> Settings --> IP --> IP Cache -> Select "Disabled" for Cache Scope.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
-vivian
