connect single pin to vector pins in BD
 Hi.
I need to make connection in BD  from single pin  of one IP to vector pin on other IP using tcl command
How to do it?
Alexandr
I think slice is similar to split bus utility, further you can look in to Utliity logic vector, utility differential IO Buffer, RAM based shift Register blocks
Currently IPI do not have everything that ISE had, but you can package and bring ISE or Vivado primitives or custom IPs in to IPI as black box.
Please check below links
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug939-vivado-designing-with-ip-tutorial.pdf
http://www.xilinx.com/support/answers/56612.htm
check this ARS
http://www.xilinx.com/support/answers/60844.html
Thanks and Regards
Balkrishan
check this ARS
Thanks and Regards
Balkrishan
