create_clock problem with OOC module
I have a design which looks roughly like the attached diagram.
Dev A has an MMCM, its being syntheszied and implmeneted in context, and contains a 'create_clock' command for the output of the MMCM.
Dev B uses this clock, and is being created OOC.  It has a constraints file scoped to it, and is set to run out of context only.  In this constraint I issue a create_clock for clk_in.
The problem I am having is after I synthesize and implement the entire design the tools thinks the clock created in Dev A is unique from the clock that is in Dev B.  If I look at the clock interaction report I will see them both listed as timed-unsafe.
Re: create_clock problem with OOC module
It would appear that removing '-name' from the ooc constraints file resolved the issue.  Can someone confirm that this makes sense?
