defining differential vector ports in IP block
I have an IP block with an output bus called laser_out [3:0] which I need to connect to an external differential port bus which I defined in my xdc file (see definition below).  I am unable to find any way to define a differential output in the IP block which makes sense as from a logical point of view the IP block outputs singled ended signals which become differential only in the physical layer when they become ports.  However when I try to synthesise the design I get the following error message.
[DRC 23-20] Rule violation (IOSTDTYPE-1) IOStandard Type - I/O port laser[1] is Single-Ended but has an IOStandard of TMDS_33 which can only support Differential.
Can you explain how to define and use differential signals as vectors/busses ?
I am using vivado to design for the Zynq7 7z020 FPGA.
set_property direction OUT [get_ports {laser[0]}]
set_property direction OUT [get_ports {laser[1]}]
set_property direction OUT [get_ports {laser[2]}]
set_property direction OUT [get_ports {laser[3]}]
set_property direction OUT [get_ports {laser_N[0]}]
set_property direction OUT [get_ports {laser_N[1]}]
set_property direction OUT [get_ports {laser_N[2]}]
set_property direction OUT [get_ports {laser_N[3]}]
make_diff_pair_ports laser[0] laser_N[0]
make_diff_pair_ports laser[1] laser_N[1]
make_diff_pair_ports laser[2] laser_N[2]
make_diff_pair_ports laser[3] laser_N[3]
set_property PACKAGE_PIN K14 [get_ports {laser[0]}]
set_property PACKAGE_PIN H15 [get_ports {laser[1]}]
set_property PACKAGE_PIN G19 [get_ports {laser[2]}]
set_property PACKAGE_PIN J20 [get_ports {laser[3]}]
set_property IOSTANDARD TMDS_33 [get_ports {laser[0]}]
set_property IOSTANDARD TMDS_33 [get_ports {laser_N[0]}]
set_property IOSTANDARD TMDS_33 [get_ports {laser[1]}]
set_property IOSTANDARD TMDS_33 [get_ports {laser_N[1]}]
set_property IOSTANDARD TMDS_33 [get_ports {laser[2]}]
set_property IOSTANDARD TMDS_33 [get_ports {laser_N[2]}]
set_property IOSTANDARD TMDS_33 [get_ports {laser[3]}]
set_property IOSTANDARD TMDS_33 [get_ports {laser_N[3]}]
Re: defining differential vector ports in IP block
You can simply use OBUFDS:
   OBUFDS_inst : OBUFDS
   port map (
      O => O,   -- 1-bit output: Diff_p output (connect directly to top-level port)
      OB => OB, -- 1-bit output: Diff_n output (connect directly to top-level port)
      I => I    -- 1-bit input: Buffer input
