Scholar ronnywebers
difference between AXI Datamover and AXI DMA
Can anyone explain the difference between AXI Datamover and AXI DMA please ? On what basis do you decide between both?
Re: difference between AXI Datamover and AXI DMA
Hello @ronnywebers,
Check the following thread:
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Which-DMA-is-the-best-choice-ZYNQ/td-p/281296
--Syed
Hello @ronnywebers,
--Syed
Teacher muzaffer
AXI DMA is built on top of Datamover and it adds some control features to it. If you want more customization go with datamover. If ADMA works for you use it.
Hello @ronnywebers,
Was the shared information helpful to you?
--Syed
Scholar ronnywebers
yes thank you!
