Scholar ronnywebers
do I need to re-synthesize after adding a new IO port constraint
These are the steps concerned :
  • block design with some IP on it
  • I put some signal on an external port
  • I synthesize the design
  • open synthesized design
  • switch to IO layout
  • in the IO ports tab, I assign the external port to a package pin
  • when I hit save, this updates the target .xdc file with the new constraint
at this point Vivado says that the synthesis is out-of-date, but that you can choose to ignore this (to save time on unneeded re-synthesis?).
Question : is it ok to ignore this? and also, if I hit 'implement design', the synthesis run is executed anyway, so what's the point of the message that you can ignore this?
Re: do I need to re-synthesize after adding a new IO port constraint
@ronnywebers,
You dont need to synthesize the design again. When you click on more info next to out-of-date, you can do force up to date which will change the option to Synthesis complete.
Check page number 66 in below UG:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug892-vivado-design-flows-overview.pdf
--Syed
@ronnywebers,
--Syed
Hi @ronnywebers
To add,
you can add a new XDC file, set the used_in property to Implementation and make it as target file.
This way if you change any pinout constraints and save the design, the constraints will be saved in to new XDC file and the synthesis will not go out-of-date.
Deepika.
Scholar ronnywebers
that's a great tip  @vemulad - if I read it correct that means that IO constraints are actually ignored by the synthesis proces? So as long as the .xdc concerned only contains IO constraints it's ok to set it to implementation only?
@ronnywebers,
Yes, If the xdc only contains IO constraints then you can set it to implementation only.
--Syed
