document for "secure_netlist"
https://forums.xilinx.com/t5/Design-Entry/netlist-encryption/td-p/756612
Hi there, in above thread, secure_netlist is mentioned. where can I find its document?
James
@james.
I don't think secure_netlist is supported in vivado. For encryption related information, Check Chapter 6 in below user guide:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug1118-vivado-creating-packaging-custom-ip.pdf#page=90
--Syed
