bhavinlapasia
example design for AXI ethernet Subsystem
I am looking for example design for AXI 1G/2.5G Ethernet Subsystem with RGMII interface using DMA. I want this example design with documentation and in block design form. The method explained in https://forums.xilinx.com/t5/Networking-and-Connectivity/AXI-Ethernet-Subsystem-example-design/m-p/929345#M15084 generates a design in RTL mode and not block design form. Does Someone know any reference for the same?
Bhavin
reshmaakhil
I think this application note can help you.
https://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf
Check the reference designs provided with this note(Links are given).
Reshma
