sanhu
how to initiate fifo with variable parameter in ise?
Core generator generated fifo has fixed width and depth. I want to write a moudle which has a fifo with variable width and depth. I want to set the fifo parameter at the time I initiate the module. How can I realize it? An example module like this follows.
module variable_fifo
    parameter data_width =8 ,      // default parameter, can be re-set when initiate variable_fifo
    parameter addr_width = 8 ,    // default parameter, can be re-set when initiate variable_fifo
    parameter fifo_depth  = 256  // default parameter, can be re-set when initiate variable_fifo
    // how to initiate xilinx fifo with above parameter ?
endmodule
avrumw
Expert
Expert
Short answer is "You can't" (at least not easily).
For a longer answer, see this thread.
Avrum
