Participant kp1998_
how to provide 1000 samples as input to the testbench
Hello
I want to give 1000 input values in the test bench through a text file.
Is this possible and if i am using the inputs values through a text file in my code how to provide 10 ns delay for each samples and and how to use it in my code for performing various computations.
Please provide some example for this.
Thank you
Re: how to provide 1000 samples as input to the testbench
What HDL language are you using?
Participant kp1998_
Hello
I am using Verilog HDL language, i know that by using $readmemh function, hexadecimal values can be read from a text file, just wanted to know how to use the values that are read from the text file as input for the code
Scholar markcurry
I'd start with something like:
localparam WIDTH = 8;
localparam DEPTH = 1000;
reg [ WIDTH - 1 : 0 ] input_data [ DEPTH - 1 : 0 ];
initial $readmemh( "input_data.hex", input_data );
reg [ WIDTH - 1 : 0 ] current_data; reg [ $clog2( DEPTH ) - 1 : 0 ] rd_ptr = 0; always @( posedge clk ) // clk = 100 MHz begin current_data <= input_data[ rd_ptr ]; rd_ptr <= rd_ptr + 1'b1; end
Untested, but a start...
Mark
Participant kp1998_
Hello
Thank you for the help.
I tried this code in my testbench, error is that vivado doesnt support $readmem function.
I think it only supports $readmemh and $readmemb functions.
Scholar markcurry
The $readmem was just a typo - editted post to correct.
Mark
