ssampath
Voyager
Voyager
how to regenerate and use the only *.bd file in my non-project mode ?
Hi Frieds,
I have block design *.bd file only not all files generated while block design generation. I am using non-project mode. How to use *.bd file(i dont have all generated file) in non-project mode.
1) how to use the *.bd file in non-project mode ? (I have only *.bd file)
Any help or suggestions are highly appreciated.
-Sam
-Sampath
gabed
Chapter 9 of UG994 lists the process and necessary items for using a .bd file in Non Project mode.
Cheers
