Voyager
Voyager
how to use the standalone *.xci file in the non-project mode ?
Hi Friends,
I have only *xci file and i dont have generated other IP files like *.v and *.dcp.  I am able to use this xci file in GUI mode(In GUI i am renerating the IP ),  but if i use the same *.xci in the non-project mode like reap_ip that is not working.
vivado showing as error, i.e module not found on IP module.
1) how to use the standalone *.xci file in the non-project mode ?
i tried,
1)
read_ip <a.xci>
generate_target all [get_ips a.xci]
2)
read_ip <a.xci>
synth_ip a.xci
nothing works for me.
Any help or suggestions are highly appreciated.
-Sam
-Sampath
Voyager
Voyager
Hi Friends,
set PWD [pwd]
set ip_gen_prj XILINX_IPS
set ip_dir $PWD/XILINX
set part xcvu9p-flga2104-2L-e
set board_part xilinx.com:vcu118:part0:2.0
set xci_file $PWD/vio_0.xci
set ip_usr_fil_dir $ip_dir/XILINX_USR_IPS
create_project $ip_gen_prj $ip_dir -part $part
set_property board_part $board_part [current_project]
source ./vivado_ip_files_list.tcl
#import_ip $xci_file
generate_target -force -verbose -quiet {synthesis implementation} [get_ips]
#export_ip_user_files -of_objects $xci_file -sync -force -verbose -ip_user_files_dir $ip_usr_fil_dir
synth_ip [get_ips]
-Sampath
-Sampath
Hi @ssampath ,
Please try using the below commands
1)
set_part <part_name>
read_ip a.xci
generate_target all [get_ips a]
or
2)
read_ip a.xci
synth_ip [get_ips a]
Please replace the <part> with your target device and If you still see errors although after using any one of the above methods please share the snippet of the error.
Voyager
Voyager
HI @shameera ,
Actually i tried both before posting it. But nothing works for me. Please find the attachment.
-Sam
-Sampath
Hi, @ssampath ,
Please try the below commands :
create_project -part xcvu9p-flga2104-2L-e  -in_memory
read_ip ./fpga_r512x8bitw.xci
generate_target all [get_ips ./fpga_r512x8bitw.xci]
synth_ip [get_ips ./fpga_r512x8bitw.xci]
Voyager
Voyager
Hi Friends,
set PWD [pwd]
synth_ip [get_ips]
-Sampath
-Sampath
