ip integrator gui problem
vivado 2017.4
I have 4 Ethernet ports inside a hierarchical block, at every compilation of my design I need to delete the outer and inner connections and ports or else there would be errors regarding the bus directions (out get connected to out and in get connected to in)
My initial post (before I understood the real cause)
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/mdio-zynq-error/td-p/847270
steps that I tried:
1. only delete the outer connections
2. only delete the inner connections (ports was not deleted)
any ideas?
Hanan
Re: ip integrator gui problem
This is not a known problem that I could find.
How are the interfaces connected inside the Ethernet hierarchy?  Are they connected to Xilinx IP, user IP, HDL reference modules?
