Participant deritha-06
map error?
There are 8 errors when I tried to run map in Implement Design.
Problem is that I don't know where to modify these errors?
Please tell me if you have any suggestion.
Re: map error?
Please ignore the error message about time_cnt.vf. I've fixed it.
I also understand why there are errors in map process. I should edit the scf file firstly............
Instructor
Instructor
Re: map error?
Your project is expecting to build for a part in a VQ100 package, which has pin numbers
like 1, 2, 3, 4, 5, ..., 100.  These can alternately be called "P1", "P2", "P3", . . . "P100" for
the location constraint.
However it looks like your .ucf file has pin constraints for a BGA package.  If the .ucf file is
correct for your board, then you need to change the device selection in the project properties.
HTH,
Gabor
-- Gabor
Re: map error?
The .ucf file is generated by : Project-> New Source, select Implementation Constraints File-> Type stopwatch.ucf.....
The board I'm using now is SPARTAN-3E XC3S500E
The attachment shows the information in Design Properties.
I still don't know what I could do to fix the bugs.....
Historian
Historian
Re: map error?
So change the Device and Package to whatever is correct for your FPGA!
Advisor eilert
Advisor
Re: map error?
minor correction:
Not the device selection has to be changed,
but the Package Selection.
See if your UCF file contains some information (e.g. in a comment) about the Device and Package it was written for.
At least it has to be some kind of 2D-Pin Array (PGA or BGA Package).
Have a nice synthesis
  Eilert
Re: map error?
Thanks all of you for your kind reply.
It's because I'm fresh about this part, so many different error messages output.
As to the UCF file, I just checked out from the xilinx tutorial webpage.
I design the software part names vtut_ver as the ise11tut.pdf's introduce.
The problem is I don't know how to connect the spartan-3e board and the vtut_ver software.
Only one usb cable is enough to connect with board and computer?
One more question: "time_cnt.vf" line 23 Illegal redeclaration of 'time_cnt'. I didn't find any redeclaration of clr in this file. What's more, this file is the standard checked out file........
Re: map error?
Re: map error?
MAP/PAR related topics should be posted on the Implementation forum:
http://forums.xilinx.com/t5/Implementation/bd-p/IMPBD
