p7 axi peripheral
I have implemented a design. It was working ok. I added some debug and now when I validate the design I get an error with the p7 axi peripheral. What makes no sense to me is there is no way for me to make this connection. This is buried within the block. See the attached images.
Pete
Hi @pcaddick ,
Which version of Vivado are you using?
Can you try  deleting the AXI interconnect module and then adding the IP again ? and see if resolves the issue.
This fixed this error in some previous cases.
Raj
I'm using 2017.4. Yes, I can do that but its a pain. Isn't there some way of making the tool sort it out.
I tried replacing it but I still get the same error.
Not only that but the replacement is even worse!!!
