processes tab dissapeared
i install the latest edition of ise web pack but i when i want to synthesize my project there is no processes tab..
i tried to fin a way to enable but nothing..
does anybod now how to enable the processes tab
i attach a photo of the ise deign suite
Thanks!!!
Professor
Professor
The "Design" tab includes the "Processes" tab.  This is a split window that allows you to
adjust how much screen is allocated to the design hierarchy vs. the processes.  If the screen
split point is dragged to the bottom, the process panel disapears completely.  You can get it
back by dragging the bottom edge of the design pane up.  When your mous is in the right
position to do the drag, the mouse cursor should change to look something like a capacitor
symbol with up and down arrows attached.
HTH,
Gabor
-- Gabor
Gabor's suggestion should work in this case.
However, if you ever get to a point where you've accidentally removed windows or panes and can't figure out how to get them back, you could select Layout -> Load Default Layout.
Thanks bro! Kudos!
where is does can you find layout?
