run block and connection automation
   hi everyone,
    Whilst creating block designs in vivado, there is some instants when you should not run connection automation, why? and how to know when to run it?
                        thank you ,
Re: run block and connection automation
Hello @sosso,
IP integrator offers a feature called Designer Assistance, which includes Block Automation
and Connection Automation, to assist you in putting together a basic IP sub-system by
making internal connections between different blocks and making connections to external
interfaces.
However, please note that not all of the ports and interfaces are supported by the Connection Automation feature.
For more info, please see “Chapter 2: Creating a Block Design” of the User Guide 994:
 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug994-vivado-ip-subsystems.pdf
 “Using the Designer Assistance Feature”, on page 42, will provide you with some additional information regarding this matter.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hello @sosso,
interfaces.
Hope this helps.
Kind Regards,
Anatoli Curran,
hi thank you,
     another question I always forget, how can we program microblaze processor using assembly?
                           thanks
Hello @sosso,
As this is a separate issue altogether, please post this query on the Embedded Development Tools forum board and the expert in this area will be able to provide you with a valid answer to your query.
From my side, as a suggestion, you may want to check the MicroBlaze Reference Guide regarding this matter:
https://www.xilinx.com/support/documentation/sw_manuals/mb_ref_guide.pdf
Also, this forum thread may be related to your query?
https://forums.xilinx.com/t5/Embedded-Development-Tools/MicroBlaze-Programming-Language/td-p/25167
If you Google "program microblaze processor using assembly", you may also find more info regarding this.
Hope this helps.
Kind Regards,
Anatoli Curran,
