Anonymous
Not applicable
schematic - editor
Hallo, I'm using xilinx ISE 10.1 and I have a question about the ISE schematic editor: I have decelerated my own types in a package at library work. How can I add these package to the schematic file, to use signals, from my own types to interconnect my components, instead of std_logic or std_logic_vector, in the schematic editor? Thank you for your answer!
I wonder if it will work anyway, but here are some things you may try:
Since you have your own types, I expect you have alredy written some modules that use these Types on their inputs and outputs.
(With the available library elements it would make no sense, since all of them  use the std types.)
Use the symbol creator (from the misc menu in the PN or with the vhdl2sym command) and see if it works, or what kind of messages you receive.
If you are lucky there's some automatism that takes respect of the used packages. But I doubt it.
And, without the symbols you don't neeed to take any step further.
Have a nice synthesis
  Eilert
