Visitor jldekeyser
vhdl code in schematic editor?.
is it possible to add  vhdl code (like  signal assignement) directly in the schematic editor like a post-it? V 13.2
regards
Advisor joelby
Advisor
Re: vhdl code in schematic editor?.
I don't think that's directly possible. Create a new VHDL module with a single output that is assigned to your fixed value, and then turn that into a schematic symbol? You'll need to edit the contents of the VHDL module to change the output (rather than somehow doing it through the schematic editor), but this should do what you're after.
Advisor joelby
Advisor
You can add an HDL module to a schematic by using Processes -> Design Utilities -> Create Schematic Symbol.
Is that what you wanted to do? If not, please let us know exactly what you're after.
Visitor jldekeyser
thanks but  does not exist on my version???
I created a new source in my project   and it is a schematic one.
when I edit this file , I add some sylbols, and I would like to write some vhdl code directly from the diagram editor for exemple
 for my symbol  with signal X <15 downto 0> , I would like to write explicitly x<= x"0101"
see this exemple in the pdf file:
yellow note
thanks......
Advisor joelby
Advisor
Visitor jldekeyser
yes at least we can do that.
thanks for you help
regards
JL
