drjohnsmith
vivado 2016.1 dds ip generator gives error
Im trying to make a dds to generate a fixed frequency out , from 200 MHz in,
using vivado 2016.1 , under windows 7, in hdl 2008 mode,
I have the following error, which i seems to be a xilinx provided encrypted file.
[Synth 8-5809] Error generated from encrypted envelope. ["c:/my_folder/top_vivado.srcs/sources_1/ip/sine_gen_ii/mult_gen_v12_0_11/hdl/mult_gen_v12_0_vh_rfs.vhd":14436]
bwiec
Can you post your configuration of the core? Do you happen to notice it related to a specific setting?
Is it an upgrade from 2015.x or are you creating it from scratch?
www.xilinx.com
drjohnsmith
in this case,
   was trying to create from scratch in 2016.1
drjohnsmith
have you given the core a go ?
balkris
Can you try using updated version of vivado tool
Thanks and Regards
Balkrishan
drjohnsmith
Not easily ,
I'm a consultant, and the post was a year ago,
