vivado.bat is not a valid win32 application
I installed Vivado 2018.3 and it was working fine. Today, when I launch Vivado I get the following error -
vivado.bat - is not a valid win32 application. Please let me know how this can be resolved!
I attached the screenshot.
回复: vivado.bat is not a valid win32 application
What is the Operating System?
Hello @vivek ,
Is your machine a 32-bit OS? Can you confirm on this please, as Vivado tools are only supported on 64-bit OSs.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hi @graces ,
Its 64 bit!
Hi @anatoli ,
It is a 64 bit Windows OS
Hello @vivek ,
Can you please confirm the exact OS in your case? Is it a Linux or a Windows? If Windows 10, what exact Update is it? you can run winver command to obtain this info. Can you confirm on this please? Thanks
Kind Regards,
Anatoli Curran,
I have attached the document for windows version.
Hi @anatoli  and @graces -
Thank you for your responses! I re-install the Vivado 2018.3.
It was working for a while, I was able to program my FPGA board. But, yesterday, it stopped working again. I am getting launching time out error whenever I try to launch Vivado. Also, when I try to launch Vivado hls, I just get a splash screen of command prompt and the hls app never launches. I don't know what's going wrong here!
Scholar drjohnsmith
Are you on a work network and if so does your IT department change permissions ? It can be a problem,
Hi @drjohnsmith ,
Thank you for your response!
No, I am not on a work network! It is just a Windows 10 PC. Do you know if there can be any conflict between Vivado tool and any other tool if they are installed in the same system?
Scholar drjohnsmith
Vivado is software
you ask can software conflict with other software on the machine,
Yes,
is this your problem ? possibly,
what software / setup , a good question.
if desperate, you could install a virtual machine,
and run vivado on that
@drjohnsmith ,
I don't know if there is any conflict between Vivado and any other software.
