lnnn
vivado crash when I run the command "source .tcl"
lnnn_0-1618906467482.pngthis command can't run, if anyone can solve this problem, please tell me, thank you very much!
syedz
@lnnn
Can you share the link which you are following to source the TCL? Make sure you are using the same Vivado version mention in github.
Also, you should use supported OS with Vivado. This can be found in the release notes of vivado version which you are using.
Check this answer record for debugging general crash issues: https://www.xilinx.com/support/answers/55854.html
Share the Vivado.log and crash log files. Run the following command in Vivado TCL console and share the generated xinfo.txt file:
report_environment -file xinfo.txt
--Syed
lnnn
thank you very much! I have solved this problem.
