varsha_14
write_bitstream ERROR
I've been working on the Xilinx DPD IP v9.0. I'm having the following error when I try and generate the bit-stream for the IP core. I'm able to synthesize and implement the design successfully. However, when it comes to Generating Bitstream, I encounter the following error. Kindly help me with this.
[Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted:
zynq_1_i/RFISS0/RFIF_1/jesd204_tx_0/inst/i_zynq_1_jesd204_tx_0_0 (<encrypted cellview>)
zynq_1_i/RFISS0/RFIF_1/jesd204_rx_0/inst/i_zynq_1_jesd204_rx_0_0 (<encrypted cellview>)
If a new IP Core license was added, in order for the new license to be picked up, the current netlist needs to be updated by resetting and re-generating the IP output products before bitstream generation.
I've tried resetting and regenerating the IP output products but all in vain.
B.Varsha
graces
Do you have hardware evaluation or full license for this IP?
You can do a quick check by selecting the IP from IP Catalog, and run "license status" from right-click menu.
varsha_14
I've an Hardware Evaluation License. Verified through the quick check you had mentioned.
B.Varsha
graces
What about the IP JESD204, which the error is complaining about?
varsha_14
The Licence Status for JESD204 happens to be Design_Linking.
graces
So that's the problem. 'Design Linking' means simulation only. It doesn't enable bitstream generation of the JESD204 IP.
varsha_14
Okay, but I require the hardware description file of this design for generating the Petalinux Image for Linux. Hence, I need to generate the bitstream and include it. Is there a way out?
Thanks and Regards,
B.Varsha
graces
You'll have to have a valid IP license to proceed bitstream generation.
