Visitor cpantoja
xst synthesis tool missing
Hello
I recently installed ISE WEBPACK12.2  on ubuntu 12.04 and when creating a new project on "Design Properties", the synthesis tool option is empty.
any suggestion?
I  have the Vivado Design Suite (include ISE WEBPACK) license, Subscription end  (NONE).
thank's for any help
Re: xst synthesis tool missing
Can you post a screenshot to show the issue? Are you able to run Synthesis for your project?
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Hi.
Ubuntu is not supported OS with ISE.
Syed
Visitor cpantoja
the Synthesis tool box appears empty therefore I have not enabled the synthesis
Is the top level of your project an HDL file? Do you see "Synthesis - XST" in the process window? If you do, are you able to run synthesis by double clicking on "Synthesis - XST"?
Vivian
Visitor cpantoja
Yes, my Top level source file is HDL, but I don't see Synthesis - XST in the process window.
Did you add the HDL file to the project (project-->Add source)?
I do not see it in hierarchy window. Please add this HDL file to the project. After this you should be able to see the synthesis option.
Deepika.
Deepika.
Visitor cpantoja
Yes, I add the HDL file to project and I receive the following:
The vhdl file you opened in the text editor is not shown in the Hierarchy window. How did you open it in Project Navigator? It seems that there is an error in the Message window right before "Started : "Launching ISE Text Editor to edit sum_res_vhdl.vhd" ". Can you post that error?
Something is not good in this project. The design hierarchy is not recognized. The "Synthesis - XST" process only shows up when the top level HDL file is selected in the Hierarchy window.
Vivian
Try removing this file in the Files Tab and adding it again.
Vivian
