Adding Register Files from AirHDL to MicroBlaze in Xilinx ISE 14.7
So I've been using a service called AirHDL to generate an AXI4 register map (https://airhdl.com/index.jsp). The service allows me to download the VHDL and C header files for my registers, however I can't seem to figure out how one would go about actually adding them to Xilinx ISE and ultimately accessing the registers in the MicroBlaze Softcore Processor for a Spartan 6 FPGA. I found some sources online that should how to add them to Vivado, but I can't seem to translate that approach to ISE, or more specifically XPS. I'm sure it's possible to do it but i can't seem to figure it out, if there's anyone out there who could help me out it'd be much appreciated!
Does the airHDL provide a bus interface? (AXI, PLB)?
There is a tool in the EDK, called Create or Import Peripheral Wizard  (In Xilinx Tools)which will allow the user to create a Custom IP (with registers and BRAM),
with Interrupt support and an AXI interface.
