Visitor cdischke
Component Ports in Planhead
I`m using PlanAhead v11.1.
How can I find ports from a specific component in PlanAhead?
Best Regards
Visitor vekin06
Re: Component Ports in Planhead
Maybe this can help...
In ISE, it is possible to create "partitions" of some modules in your design (click right on your HDL file and "new partition").
If you do this, when you will import created netlists into your PlanAhead project, you will be able to see your module as separate block, and then you can use the schematic view to see ports (click right on your module instance and "schematic").
Best Regards
Visitor sureshwar
When you synthesize set the option to keep hierarchy. Import this netlist into planahead.
You should be able to see the components as per the hierarchy of the HDL
hope this helps.
