stanstanev
Exporting IO report in Vivado to CSV which includes explicit Zynq MIO pins used
I am not sure if this is the right sub-forum to post this question.
I am using Zedboard (with the Zynq device) but I would like to create a custom board for my Zynq design. In order to design my schematic I need to know exactly what pins are mapped out on the Zynq, including what MIO pins are tied to each enabled peripheral.  When I export I/O ports (from the File menu), Vivado doesn't specify the peripheral pins, instead it just shows the generic MIO pins like this
  C12 IOPAD_X1Y130 PS_MIO53_501 46.065 46.528 FIXED_IO_mio[53]
  D10 IOPAD_X1Y129 PS_MIO52_501 34.642 34.99 FIXED_IO_mio[52]
  C10 IOPAD_X1Y128 PS_MIO51_501 40.853 41.264 FIXED_IO_mio[51]
  D13 IOPAD_X1Y127 PS_MIO50_501 62.403 63.03 FIXED_IO_mio[50]
  C14 IOPAD_X1Y126 PS_MIO49_501 73.235 73.971 FIXED_IO_mio[49]
Is there a way to export all the signal names and pin numbers for the enabled peripherals (USB, Ethernet, UART, etc.)?
vemulad
Follow the process below
1. Open block design.
2. Double click on zynq processing system.
3. In MIO configuration tab, right click on any of the IO peripheral and select export to spreadsheet.
4. Select the the location for XLS file to created and click on OK.
Now check the generated XLS file. Let us know if this has the information you are looking for.
Deepika.
Deepika.
vemulad
Deepika.
Deepika.
sstanev
Great,
that works.
Thank you
vemulad
As the query is answered, you can close the thread by marking post which helped as "accept as solution".
Deepika.
Deepika.
corydearing
I am using Vivado 2018.3 and I get no context menu when I right click on any low speed peripheral in the I/O Configuration pane.  Has this feature been removed?  Has the feature been implemented in a different way?  It would be great if the version of Vivado that applies to the solution could be explicitly included in the solution.  Thanks.
-Cory
