hamidce
How to write bitstream to ICAP in partial reconfiguration?
I want to use FPC (XAPP 883) with my own software and transfer the bitstream by LAN.
What is the write flow to fpga? (SOC, SYNC,Data, EOC)
should I remove the header of bitstream?
How does PR Loader software extract the bitstream?
martink
generally speaking the flow is pretty simple. You need to make sure that the "real" PR bit-stream ends at the ICAP-module correctly.
The SOC/ EOC-pattern in the application-note are just arbitrary pattern that were used in the example-design for a bit off control what is happening. The ICAP-module itself does not care about it.
Where it starts to get interesting is when the real bit-stream comes along with the SYNC-pattern and the alignment-word. These need to be located at the right boundaries. If you are going for an 8 Bit Interface at the ICAP you don't need to worry, however if you go for 16 or 32 Bits than you need to make sure that the SYNC- and alignment-pattern are properly distributed over the 16/32 Bits.
I seem to remember that the example-design didn't like it when the PR-bitstream came one or three bytes short (in my case some additional data before the initial FF FF ...) and hence the word-boundaries on the ICAP were missed. But a lot of dust on my memory on that topic...
The real PR-bitstream needs to be fully loaded into the ICAP-module, otherwise you will not get a correct reconfiguration.
Hope that helps,
Martin.
