IEEE-1735-2014 v2 - Generate Key?
Is there a note about how to generate keys for encrypting IP?
If you want to your code to be read by a specific design tool, you have to encode it using its public key. For Vivado it's the one found in the installation directory. For other tools you can find the key either in the documentation or in the installation directory. If your design flow uses several EDA vendors, you can encrypt your files with all required pub keys.
Therefore if you encrypt it only for use with Vivado -> use the Vivado key. It makes no sense to use another one. Vivado must be able to decrypt your file anyway. If you target different uses of your file (ie outside Vivado) encrypt with the Vivado key and your own key.
You can just use the key file in the Vivado's installation dir:
Ex: .\Vivado\2019.2\data\pubkey
That doesn't make sense to me - I'd want to control both the public key as well as the private key.
I need to be able to generate a public/private key pair (either with PuttyGen or ssh-keygen) and then utilize them to encrypt the IP.
I used the following command:
openssl genrsa –out some_key_name.pem 2048
Then I extracted the public key:
Openssl rsa –in some_key_name.pem -pubout > some_key_name.pub
Then I placed the pasted the public keyfile into the example keyfile_vhd.txt, and launched an encryption run:
encrypt -key /path/to/keyfile -lang vhdl -ext .vhdpp /path/to/source
So that looks like I can create the encrypted file (hooray!) however when I try to add it to the Vivado project, I get a syntax error on the file and Vivado can’t seem to parse it.
I must be doing something wrong.
I thought it would be possible to provide a customer a key, which they could use, then access to the key could be controlled as well.
It does not look like that's the case; this is the best we can do with IEEE-1735 (barring a new revision and tool support, of course).
