lucc2
LVDS* show up in red in vivado, HighPerformance bank, Ultrascale+ MPSoC
I am having problem assigning some LVDS* signals
They always show in red in vivado looked at other post but did not find the answer on how to fix.
These are IO in High Performance bank.
Any pointers?
bruce_karaffa
What version of Vivado.  Are the signals inputs or outputs?  What voltage is powering the bank?  What other IO standards are used in this bank?  Are you using the internal termination resistors?
bpatil
Hi @lucc2
Along with details requested by @bruce_karaffa, Error message details and snapshot will be very much helpful to understand issue.
Bhushan
sandrao
Community Manager
Community Manager
Hi @lucc2
bruce_karaffa is as usual spot with his questions. The version of Vivado is very relevant.
I filed a Change Request against 2020.1 as I had seen the same behaviour, the IOs would turn Red but when you run the DRC no issues are flagged.
The issue was resolved in 2020.2.
I would suggest starting with running the DRC, if there is a DRC flagged then the IOs should be showing up at Red. Then bruce_karaffa's other questions is what you need to look at, direction/voltage/IOSTANDARD/Termination.
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
